(67) 425 olds
Moreno_831
Mar 25, 2020
23
4
The 165 is a hair low. Not terrible.
Driver side was 180 all across passenger side was a bit up and down.... just sent the carb off for a rebuild... I should get a couple more years with this compression? Not trying to open it up.
TURNA
189
96
NY
You will be fine
worst case is check the 165 cylinders plug so its not fouling out from oil
Moreno_831
Mar 25, 2020
23
4
Can anyone tell me what these vacuum are for? Should there be a hose or just plug them 67 olds delta 88 425cu
Was that one open? If so that could very well be your poor running issue. Yeah just plug them.
Reactions: Moreno_831
Moreno_831
Mar 25, 2020
23
4
Before and after carb rebuild
Reactions: TURNA
