455 Olds@78
- May 4, 2021
- 17
- 6
- 3
I was told by the original owner that the 403 was .030 over. I never measured them. The shop I sent the short block too that measured them and marked it on a piston... sorry for not verifying.That's OK; his 0.030" pistons measure 0.0255" over!![]()
As far as the "Victor" manifold, I corrected the model number to 2811 and it's for a 455 olds (got my manifolds mixed up. I do have a single plane, air gap manifold for my 403 also. here's the Victor manifold link ... hopefully
2811 Edelbrock Olds Victor Manifold
$444.00 – $844.00Designed for the ultimate Pro-Street/Drag Race/Marine applications. This new Victor Manifold bolts right on the Edelbrock Performer RPM aluminum cylinder heads or stock cast iron heads for the 400-455 Oldsmobile engines. Uses an enlarged flange for a 4500 series carburetor. We can modify this manifold to fit under stock hoods. (Will not fit without modification.)
| Options | Choose an optionExternal Polish ($844.00)Standard ($444.00)Hood Mach ($544.00)Ported ($744.00)Ported w/ Hood Mach ($844.00)Clear |
$444.00
Out of stock
ADD TO CART
Add to Wishlist
SKU: N/ACategories: Intake & Fuel Systems, Intake Manifolds
