Painted up these...
265
Now I just need to pick up, the alternator, Ford crank pulley and billet brackets.
452
Reactions: Dr78442
265
SBC truck setup. The SBC crank pulley hits the water pump pulley on an Olds V8. I ground it enough to clear but I have misplaced mine. Many use the slightly smaller SBF pulley, my Daughter's boyfriend has a 351W pulley. You can also see where I cut the bracket below the idler, it interferes on the Olds V8 with a mechanical fuel pump.
