Olds 350Diesel build
sam
Hello guys new here but been watching for years when i need advice on olds builds ok old topic olds 350 diesel build i don't have the DX block only could find a D block is it just as good for a high performance build as the DX only difference i always hear is the .921 lifters looking for around 1500hp give or take 100 billet 425 crank and internals want to get as many cubes out of it as possible without it becoming weak going efi big and ugly hat studs cylinders and crank with gridle want it to run on methonal roots blown maybe 8-71 street/strip leaning more to strip money isn't a problem don't believe in going cheap on a build wanna do it right the first time so will the 350D block work or should i try to find a DX block i want you guys to tell me what to do hell we can help build it together i listen
Yes, the D block is just as good. The only issue is to make sure the main bolts are tapped deep enough. Contact Mark Remmel at New Olds Performance at [email protected]. He even did a run of Billet 4340 stroker cranks, much stronger and lighter than the 425 crank, good luck.
sam
Sep 3, 2023
Thanks that all i needed to hear because i couldn't find nobody speaking of the D block in a high performance build and will do
Jul 9, 2024
Ok I like the big bore lifters you can get a better Campofeli and yes the 400&425 crank will spin in that block but you have to cut the conter weights down and have a pear of stage 3 aluminum heads that that flow 365 on the intake and can be ported to flow 400 and I also have the intake manifolds that gos with them give me a call mike at 816 449 8676
Jul 9, 2024
Jul 9, 2024
!I have crank spacer to put the 330 olds still crank or 350 crank in the DX or D block for sale
For sale stage 3 CJ BATTEN Heads and intake manifolds & olds nascar block with forged crankshaft with chevy 0.020 under H beem 6.100 rods & ROSS 14 TO ONE COMP ROLL LIFTERS AND STILL BILLET CAM WITH NEW STILL FLYWHEEL AND CLUCH AND BALANCER ALL NEW HAS NEVER BEEN ASEMBELD THE BLOCK IS 4 BOLT WITH SPLAYED CAPS
