Help with Olds 307 Project
What cfm is the Holley carb? It will probably be way rich as is and the square to spread bore adapter as mentioned. He will need stock replacement pushrods for a 85 to 90 Olds 307 Vin Y. They are different as that motor has the taller roller lifters. Surprised a flat tappet doesn't go flat using the roller lifters.
Distributor should work fine, be aggressive with the timing. A 600 cfm is plenty big for that 307. The push rods sound right. My regular, no roller cam push rods are just over 8" long. I believe there is about a 1/2" difference between the two.
What about the 58070 part number? They seem to be the same, just un-coated...
Yes. Quite often there is something like -1 added to the part number for ceramic, this has an actual different part number.
yitzac1990
15
Huntsville, AL
Yes, that Mr Gasket adapter will work.
Reactions: yitzac1990
