Self-Inflicted Wound
Shurt24
10
Little Rock, AR
Hi all, I’m new here, and have come to confess.
I ran my 403 out of oil. I heard a slight ticking, failed to check it in time, and it began running really rough. Got it home, got some oil in it, and that tick turned into a KNOCK.
I fired it up one more time to move it to where I was pulling the motor, and it ran extremely rough. No power, seemed like the entire motor was out of time.
Got the engine out, torn all the way down to the crank, and have seen no obvious culprits. Looks like the bottom a valve is charred. Looks like a piston has been hit a couple times, but doesn’t look like anything major has gone wrong. Not to cause that kind of running issue.
before I pull these bearings, is there anything I can do/check/test?
  • Wow
Reactions: GP403
Did the timing chain skip? Was the motor really hot? Was it a center exhaust valve? The valve could be bent after contact.
Shurt24
Sep 30, 2019
10
Little Rock, AR
Timing chain was solid. Motor didn’t seem to get hot. I’ll get some pictures of the damage I found posted tomorrow.
Thanks for the quick reply.
That makes me think stuck valve. Were the heads done recently? A few guys have had center exhaust valves stick. Machine shops put the clearances too tight, they need a minimum. 0028" is my understanding. Those big center exhaust crossovers create a lot of heat. I picked up a set of fresh machined #6 heads. I checked the guide clearance, right around .003" clearance, 0 issues running them.
I used snap gauges with micrometers. My guess is your shop set the center guides to tight. Which cylinder has the contact?
72
37
This sucks, sorry you're having to deal with the fallout. I have a buddy, a self-proclaimed "non-car guy". He bought a newer vehicle, because they're "reliable". At some point, I got the impression he hadn't had an oil change in a while. I asked him how long. He said "oh, 20k miles". ?!? Asked how long since he CHECKED it. "Never, don't know how". So I immediately checked it. There was just a little nugget of black tar on the end of the dipstick. Ended up putting 4 quarts in a 5 quart system. No apparent ill effects. (APPARENT) But I guess they ARE reliable. I always feel sick when I wait too long and have to add a full quart.
Matt69olds
107
110
Reactions: Shurt24
Number 8 looks oily. Is #2 kind of carboned up? I think some guide measurement is in order.
130
Start pulling the short block apart. You probably have broken rings (detonation) broke piston skirt, maybe rod bearings. Looks like loose valve guides, oil problems #2 & #8.
