SBO serpentine kit adapter plates With mechanical fuel pump
Trader history (0)
Extreme Supreme
15
11
michigan
SBO Serpentine Adapter Plates with mechanical fuel pump.
$200 PLUS SHIPPING
Here are some pics of the SBO adapter plates I make to mount the mid 90's chevy serpentine brackets to a SBO with a mechanical fuel pump.
If you are installing this into a G-body it will require two button head cap screws. The bolt that goes directly over the fuel pump needs to be a BHCS. There just is no way to get a wrench on it with the fuel pump in place.
The other BHCS will be needed on the top of the steering gear box. It gives just a little extra clearance for the P.S. pulley.
I will include those as well as the Stainless Steel Cap screws to mount the adapter plates to the engine. The 4 metric bolts that mount the water pump pulley and the bolt for the lower support bracket will also be included. Two 3/8" bolts for the adapter plates to the lower support are included also.
You will want to get the bracket that supports the AC unit and the intake bolt off the donor truck. This piece keeps the belt from moving when you start the engine.
The ford crank will also need to be modified. The mounting holes need to be recut and the pilot hole needs to be welded and re-machined to the Olds dimension. I can do this for you also for an extra $40
Video link
One thing you need to find or it will not work is the RWD reverse rotation Olds 4.3 V6 diesel water pump. The FWD WP is different and won't work. These brackets will space everything properly and allow more than one bolt to attach the bracket to the drivers side. I plan on comparing the G body A/C line to the 94 sbc A/C truck compressor I have with my serpentine brackets.
I found another place that also has these adapters. They have an adapter ring to line up the Ford crank pulley. I have an Olds underdrive crank pulley that is useless due to under driving the water pump. I am going to cut off the bottom and make the alignment ring for free.
do tell do tellllllllll
As said, a stolen design by Pacific G body. So I am flinching their alignment ring idea, since they stole the bracket design from Larry.
Email sent
Did you ever get the power steering pulley measured? I need to get mine on in the next few weeks.
Guccipucci
Where can I purchase the adapters at do u have a name or phone to the place or person
