Water pump pulley
TeeBone
10
Good morning. Proud owner of a 1984 Oldsmobile Toronado. I'm looking for a water pump pulley. Any assistance would be greatly appreciated. Thank you.
You need a matching set to work properly.
What accessories do you have? Any letters on the pulley?
Is it damaged? I might have one, does it have three grooves with one slightly larger at the back?
Hmm, never seen a 307 with one groove on the water pump. Usually two with a bigger groove for the air pump. It has been years since looking under the hood of one of these FWD 307 powered cars.
TeeBone
May 25, 2023
10
I have pics I can send.
Are you running an A/C belt? That will cause endless squealing to the point of burning off belts. That may be your issue. I have that pulley and the matching lower dual groove crank pulley, both stamped with D on the front. I will send for the price of shipping but I am in Canada.
Where are you?
I will get you an estimate in the next few days.
It looks like $37.50 US to ship, going off the online calculator. If you aren't running belts on both crank pulleys and one on the A/C compressor, different pulleys won't fix anything, as a FYI.
TeeBone
May 25, 2023
10
Ok sounds fair. How do want to set it up?
I do have a 307 off a Cutlass and Delta 88/98 307 big car. Send a pic of that as well, it may be different. I have both pulleys already packed. I take PayPal, [email protected].
64
last post was in june so maybe Tee Bone now has these parts .
Melville i agree . Cannot run that engine without the AC belt in place . The pictures show the AC pump in place but no AC belt on . The AC belt helps turn the water pump pulley or the power steering belt will squeal .
Tee Bone says the water pump has one groove , the pictures show the water pump has 3 grooves , could Tee Bone be talking about a different pulley ?
On my 307 the water pulley had a wobble turned out to be the bearings in the water pump . So could be a new water pump pulley might not fix that . How could Tee Bone confirm that ? remove all belts then grab onto pulley to see if it feels like water pump bearings ?
Tee Bone has an AC pump in place , why would Tee bone need an AC pump bracket ?
