OLDS #7 Heads
33
Are #7 heads any good?
I think they are 1971 heads so they have to be better than 4A's?
Thanks
89
Yes, they are. The only heads worse than them are the other #A heads.
33
Thanks guys
going to keep the 4A's not going to do the drilling that is needed to be done for them to fit
  • Sad
Reactions: JAMCAR223
89
It isn't hard to drill them but if they need redone, it adds up too quickly. You are just looking for cruiser so the 4A heads will be OK. They do flow way better than the 7A heads on your 307. I say throw in the cheap generic version of the 204/214 cam and have fun.
JAMCAR223
26
5
HOUSTON, TX
Old
12-25-2011, 09:07 PM
Copied from HotRodders.com
This is what I will be doing. It looks like the best HP for the $$. Combine that with a streetable cam, dual exhaust, and a 4 barrel carb. Seems like the way to go. Get some extra HP by using electric fuel pump and/or electric fans. Get a better HP to Weight ratio by making the car a little lighter.
Aliminum- intake, radiator, core support, hood, bumper supports, bumper brackets, wheels, rear brake drums, etc.
Use a mini starter for less weight.
pricesgarages's Avatarpricesgarages
pricesgarages is offline
Registered User
Wiki Edits: 0
pricesgarages's Photo Album
403
i ve built a few 350 headed 403 they are powerfull and yea they are a small bock olds did make a big block 400 425 455 and the heads will interchange
ok but back to the 350 being a 70 they should be casting no 6 5 6 and 7 are the best ok first u need to drill the head bolt holes to fit the 403 head bolts
2nd use 403 intake vavles NEVER USE THE 455 2.07 the 403 intake valve is 2.00 the smaller cc should bring a stock 403 to 9.2-9.5 compression and any intake will bolt on to it u can use 455 heads but u need a ported performer rpm intake and flat top pistons the 455 have the same cc as the 403 so it wouldnt increase compression like the 350 heads do with out porting or any other mods expect 50-70 hp more withe the 350 heads on your 403
