Old 09-17-2010, 07:17 PM   #1
johnb5345
johnb5345's Avatar
Default PF61 vs. PF61E
Does anyone know the difference between these AC Delco oil filters? I'm changing the oil and the one I put on before is a PF61, and the one I just bought (from Walmart) is a PF61E. I compared them and they're the same size but the inside of them aren't the same. Can I use the PF61E on my 307?
Old 09-17-2010, 07:21 PM   #2
84 H/O
84 H/O's Avatar
Title: Turbo Tard
Send a message via Yahoo to 84 H/O
Default Re: PF61 vs. PF61E
Check out this thread.
http://forums.trailvoy.com/showthread.php?t=73886
Tony
1969 442 convert- 400, 200-4R, 3.73 posi, OAI, every option but cruise and power locks
87 Sunbird GT turbo convt - 13.61 @101, 260 whp/350 wtq. Not bad for only 2 liters huh? Same size as a coke bottle........
2009 Solstice GXP- quick and handles like it's on rails. I love these turbo 4 bangers!
2012 Ford FX4 Ecoboost V6, murdered out and ghetto cool
Old 09-18-2010, 04:35 AM   #3
pavemobile
Title: Proud Olds Owner
Take a spin over to www.bobistheoilguy.com and do a search for E-Core filters; lots of info over there on oil & filters, and additives.
Old 09-18-2010, 04:43 AM   #4
mkube396
mkube396's Avatar
Title: critical mass
Send a message via AIM to mkube396
IMO i would say away from the AC filters now there made wors then the Frams now. the end caps are crappy glued plastic and the inside cage is thin plastic.
1981 Chevy monte carlo 396 BBC .060 over 9.7:1 voodoo 60203,
3:42 Posi GTA rims
Upcoming 700R4 swap
8.61 1/8 mile on street tires
Old 09-18-2010, 07:52 AM   #5
69hurstolds
69hurstolds's Avatar
Title: Soylent Green Processing Facility Supervisor
I don't think they're horrible filters for the grocery getter or stock weekend cruiser that you do regular oil/filter changes on. I've got a couple of cases of 61's I got to use up, so it's going to be a while. They were Ebay specials I bought a few years ago for 9.99 per case, so I couldn't pass it up.
For my every day drivers, I'm using Wix filters which have more square inches of filtration area and better micron size to boot than the Delcos and are just SLIGHTLY more in cost. FWIW, once I switched to wix (or Napa Gold), my oil pressure has gone up a bit even to notice the change on factory gages.
http://www.oldspower.com/photopost/data/500/medium/874423.jpg
If you don't like something, change it. If you can't change it, change your attitude. Don't complain.
Old 09-18-2010, 08:44 AM   #6
joe_padavano
joe_padavano's Avatar
X2. I used to use AC filters exclusively, until they changed the design. The top plate (where it screws to the adapter) is now flat, much thinner, and as noted not welded. Also, every one of their filters seems to be shrinking. My truck takes a PF1218, which used to be a full quart filter. The same part number is now a half-height filter. I've switched to NAPA Gold.
Joe Padavano
62 F-85 Deluxe wagon (the NV desert car)
62 F-85 Deluxe wagon (the San Jose, CA car)
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
Old 09-18-2010, 09:46 AM   #7
olds307 and 403
olds307 and 403's Avatar
Hastings or Wix only.
1988 CSC, Ported #6, 9.5 to 1 Olds 350, 2004R, 3.42 open for now.....
Old 09-18-2010, 10:14 AM   #8
69hurstolds
The more interesting part is WHY do you only use Wix or Hastings?
For example, even though Hastings/Federated are made at the same manufacturer, I'd go with Hastings because...
Doesn't mean the Hasting filter is BETTER necessarily, but it appears there's a big difference in quality.
Old 09-18-2010, 10:44 AM   #9
olds307 and 403
That is a big difference . I run Hastings because I have heard good things and can get at Peavy Mart, they switched from Fram. I also run Wix or Napa gold depending where I am buying them. The Corolla uses a tiny filter and usually get Hastings, bit cheaper. Is the NAPA Gold identical? I was told the Auto Sense brand up here is also supposedly made by Wix but probably the cheaper filter. Way cheaper may have to cut one open to see what is inside.
Old 09-18-2010, 11:36 AM   #10
69hurstolds
It is a common perception that Wix makes Napa Gold filters to their specs. I'm not saying they don't, as they probably do, just can't say for sure they do. They may be the exact same filter as a wix with a different color/label.
Old 09-18-2010, 12:15 PM   #11
It usually says on NAPA gold filter boxes that its manufactored by Wix, at least everytime I checked (to make sure their not switching manufactors on me). Polulator (sp?) makes a really good filter from what I read along with Mobil 1.
